951 Won't rev above 5200rpm
5th Gear
I have changed or tested with another: fuel pump, FPR, injectors, AFM, spark plugs, rotor, distributor, DME box, KLR box
I have measured plug cables and resistance in crank position sensors.
What is left to test?
5th Gear
I have replaced the cat with a pipe.
I have also replaced fuel filter
Could a faulty ref or speed sensor cause this problem? I mean if it is giving sufficient signal at low rpm but something happens at high rpm?
Yes, if the gap is not correct... at high RPMs it's capable of putting out ~50v peak believe it or not. If the gap is too small that voltage is even higher, and if it's too large, the signal may have a solid voltage reading but loses sync as the frequency picks up (at 130 teeth, it has to register over 11,000 teeth / second at 5200 rpm)
