cam tensioner
Old 10-13-2003 | 06:10 AM
adrian_jaye's Avatar
adrian_jaye
Question cam tensioner
also can I get a check on this part.
The cam tensioner has a pad, which can be replaced.
However OEM have this description, can someone pls verify it ?
944-105-213-01 - Securing Clip (Belt guide) ?
cheers
Old 10-13-2003 | 06:34 AM
Luis de Prat's Avatar
Luis de Prat
Only the top pad can be replaced. I believe it's a 928 part.
Old 10-13-2003 | 08:53 AM
thedyingiraffe's Avatar
thedyingiraffe
I know that you can get one here in engine mechanical category:
http://www.allzim.com/parts.html
ZIM.105.049.RAIL
The picture says it all.
Old 10-13-2003 | 07:32 PM
adrian_jaye
hey Luis,
the whole tensioner is about £200 odd the pad is £1.20 ish,
I dont know how easy it is to replace just the pad without losening the camshafts ?
I seen the 2 bolts and the oil pipe, but its still a tight squeeze under the chain
ideas ?
Old 10-13-2003 | 09:09 PM
Riff's Avatar
Riff
Top pad from my old tensioner has the PN 928 105 509 01
No need to remove the camshafts to replace the pad, though I do think you should remover the tensioner to replace the pad. You are correct, there are only 2 bolts and the oil pipe to remove in order to get the tensioner out. You will need to compress the tensioner (press straight down on the pad) and then lock it inplace with a paperclip bent into a "U" shape. See the side of the tensioner for 2 small holes to insert the clip. Undo the bolts/pipe, remove, replace pad and then put it all back together. Be careful not to drop one of the small crush washers for the oil pipe down into your motor. Best to stuff some paper towels into the oils galleys to save you some grief later.
Good Luck,
Old 10-14-2003 | 05:00 AM
adrian_jaye
Good Luck,
Thankxs Riff,
thats exactly how I needed to read it.
some procedures are a bit roppy,
that makes sense,
Ade
Old 10-14-2003 | 10:46 AM
AndyK's Avatar
AndyK
Default This site says it all
Here's how I learned how to do it!
Cam Chain Tensioner
Old 10-14-2003 | 12:54 PM
Riff's Avatar
Riff
Hey Adrian-
One other tip...Upon re-installation of the new pad and tensioner, place some motor oil on the pad and chain to pre-lubricate the system. You do not want to hear the sound of it starting dry before any oil gets to the pad...Made me cringe when I did it.
HTH,
Old 10-25-2003 | 10:20 AM
Rally Guy's Avatar
Rally Guy
That's a great tip - I'm doing the whole tensioner today and I'll bet you just saved me 10,000kms or more wear on that brand new pad.
Thanks!
RK
Quick Reply: cam tensioner
