Bought a 1987 944s!
#61
I believe that is the Lambda probe connector. In the manual it shows testing it for reading a lean/rich mixture and it's location is exactly where this plug is.
Apparently on the 87 they decided not to have this active or only allow shops to connect a testing device to it. 88's have it connected.
I've never connected a voltmeter to mine so now I'm curious if it is active or if this is just coming from the DME and the 87 engine is missing the probe.
#62
Ah, thanks for the tips guys. It is that exact connector, so I guess it's not supposed to go anywhere.
All of the other engine connectors appear to be fine, so I'm wondering what else I should try. If anything I should just do some basic compression tests to see the health of the engine.
I found another funny little tidbit today in the car, it was an oil change sticker from a Jiffy Lube. It said to change the oil by 119,000 miles or by 6/12/2011. So there's a good chance this car hasn't run in like 5 years.
#63
So you still don't have any hints of it starting? You might even have to get a replacement DME if all else fails. Also check for a collapsing fuel line at the fuel pump.
I you have tack bounce as you said then I suspect the sensors are fine.
Your injectors may be toast too but typically you would get something out of them.
Chris
