944 power steering Rack part issue, help
I rebuilt my rack and have 2 parts left over!!!!!!!! What a dope I am!
One is a brass washer and the other is the same ID and OD, stainless steel, same size as the center thrust washers.
Have scoured the net and different sites and everyone is clueless.
All experts out there?
HELP!!!!!!!
HELP!!!!!!!
Skip ahead to 9:20 on the video. The only thing it can really be is the lower washer for the thrust bearing. I also don't think it is brass, but coated steel. Yours does however look thicker than i remember.
Just to follow up I did not have either of the pieces you mentioned. However, if it is the same diameter as the trust washers then you now where it goes. Do you have any in/out play in the spool valve, if you were to pull on the input shaft? What year 944/rack are we talking about for reference?
