Heater clip fix - zip tie okay?
Suffered the common heater "mixer flap" clip breakage today. Easy to fix IF you have a new clip - which I don't.
Can I zip tie the rod to the arm for a couple of days?
Forever?
Thanks,
RK
Forever?
Thanks,
RK
Re: Heater clip fix - zip tie okay?
Forever?
Thanks,
RK
Forever?
Thanks,
RK
It's starting to get a little cooler here in San Diego.
I've used a "speed clip" usually used for mounting automotive speakers and a zip tie - but I found it's tough to get the rod tight enough against the motor arm without binding. The OEM clip allows free movement through a prependicular axis and I can't really recreate that with the zip and still hold it tight so the flapper door fully closes (no heat). I don't want to generate too much resistance and burn out the motor. Zip fix will work for a couple of days - but I'll order the clips.
Thanks,
RK
PS. No, winter has not arrived - we've had a couple of cool mornings - but it'll be in the high 60's this week.
Thanks,
RK
Originally posted by PSUice944
My Zip Tie has been going now for (drumroll please)
6 years!
And I just got the real clip in the other day for the heck of it. Maybe one of these days (read "next year") I'll actually "fix" it!
YMMV
6 years!
YMMV
[Don't fix it if it ain't broke]
