944 s2 radiator fan keep turning
Hey
My radiator fan was keep turning when key was inserted and keeps turning all the time.
It was like this when I bought it.
I changed the temp sensor on radiator and was going to change the connector to.
Then I saw the reason there is a wiring (see picture) when I disconnect it fan stops when I connect it fan works again.
I made a test I drove the car until it was warm then I disconnected the cable fan stopped.
So cable needs the be connected to eatch other or car will overheat.
Does someone know where the cable should be connect to?
