Anyone w/ a dead DME ?
Anybody that has a dead DME sitting around, I'd like t hunt one down, all I really want from it is the (male) connector assembly that attaches to the wiring harness connector. Could actually use both 35- and 55-pin versions.
Originally posted by 89magic98
Just curious, are you trying to fabricate a signal break-out box, like the bosch uni-tester:
http://frwilk.com/944dme/ett01801.htm
Kevin
Kevin
Yeah, I'm already done actually, just don't like having individual pins that I have to stick in the harness connectory. Time consuming, flimsy connection, invitation to hook it up wrong. Mine's not nearly as fancy as the Bosch, just a pin-out so I can look at signals w/ voltmeter or scope with everything connected.
Interesting.
I'm working on a visual display that will fill the empty speaker hole on the early 944's. Will show all of the critical DME imputs and outputs.
Also thinking of using it as a targeting system for the 25 mm cannon mounted under the car.
Originally posted by SoCal Driver
Interesting.
Interesting.
Not enough room under the car for such a devce. I found the perfect spot under the top of the fender on each side for dual miniguns with ammo feed where the windshield fluid resevoir goes
We Californian drivers know the necessity of such devices on our cars.
Interesting.
Interesting.
I thought of something similar, but very simple - both switched outputs of the dme relay, and 3 leds that could keep up with the speed/reference sensors, and the ground signal to the coil.
Big E - do you have a DME pinout in electronic form? I have a schematic, but it would be easier (than making the list myself) if someone already had a concise list of pin # and function.
Thanks.
Kevin
Thanks.
Kevin
Thanks.
Kevin
Thanks.
Kevin
