Now down to the DME.
Still chasing the issues with the car not running/hard start. To date, found bad connection at the Speed Sensor connector and replaced that and did voltaqe tests on the replaced AFM (old one had defective resistive readings) and the voltage readings and resistance readings from the new temp sensor to the AFM are all good. The one things I was puzzled about is the Clark's Garage refers to pin 6 of the AFM being ground when in actuality doesn't seem go to a ground per se but appears to be "common" path that is internal to the DME.
In any case, after all the trouble shooting and component replacements, it appears that I may be dealing with a DME issue. I have a loaner coming to eliminate this possibility.
