checking knock sensor?
Guys is there a way to check the operation of the knock sensor? The reason I ask is because I am currently working on the top of the engine replacing a bunch of hoses, vacuum lines, installing venturi delete, and checking sensors for their operation as well as cleaning them up. I am also going directly to a manual boost controller setup avoiding the cycling valve so I assume that the knock sensor is very important to me at this point.
Look forward to hearing
Paul
Paul
Paul
Paul
