Well, the load is carried by the fabric on the very outside of the belt.
The rubber 'teeth' just couple the torque from the pulleys to the fabric. The teeth only have to be firmly attached to the fabric and not to each other.
There are no missing teeth, every tooth is attached to the fabric. There are just cracks between the teeth.
So...that's what I meant by cosmetic. Works fine, looks wonky.
I wouldn't suggest the criteria for replacing an automotive belt be when it's missing teeth. Granted, worse thing that will happen is you will be without power steering, however, allow the system to work as it should and don't let that happen. I'd get a new belt.
944Time, I know what you mean but in trying to think of any downside, I imagine that the longitudinal movement (play) of the teeth is higher than normal in the even of, as you call it, torque coupling. That would relate to a slight delay in powered steering.
Does this matter? No. Will you notice a difference? Hmmm...no. Can you use it on a road trip if you don't have a spare? Yes.
Conclusion: The belt is totally fine but there's damage that's beyond cosmetic.
Here is what will be happening to your PS system - a belt in this bad shape no longer runs smoothly with a negative bearing on your PS pump. Your pump will be ruined and you have not saved anything.
Don't try to save $$$ where it is important to invest some money to keep your car maintained well. A new pump is more expensive than $10.
Hold a piece of copy paper by its two upper corners and pull it tight. Notice how you can pull pretty darn hard before ripping the paper? Now put a quarter inch tear along the top edge and try again. Notice how it pulls apart like butter?
