Changing a leaking cam cover gasket-Guess how much!?
Old 09-23-2003, 11:12 PM
AndyK
AndyK's Avatar
Exclamation Changing a leaking cam cover gasket-Guess how much!?
Brought my car back to the mechanic who charged me over $400 to fix my leaking oil pressure sender. Car is still dripping oil on the floor, and I wanted them to see if they messed up the installation, or something.
So I get a call back that the leak is from the valve cover gasket, leaking down the side of the block and pooling, eventually dripping to the floor. Anyone want to take a guess at how much this place wanted to charge me to unscrew the bolts on the valve cover, replace the gasket, and screw it back together??
A mere $295!
"It's a mad house!! A MAD house!!" I told him forget it, and got a receipt saying "small gasket leak--customer decided to do nothing at this time."
Where do I get a short valve cover bolt (mine's stripped), and, what should I use to SEAL the gasket this time so it doesn't leak? My gasket is brand new, but since it was used, I assume I should buy another one to make sure it seats right??
Old 09-23-2003, 11:15 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Dude! Take it to my guy, I will drive you to the damn train! (Not kidding!)
Old 09-23-2003, 11:30 PM
Z-man
Z-man's Avatar
Andy: give the guys at Powertech a call. I'm sure they can help you.
-Z.
Old 09-23-2003, 11:47 PM
User 41221
User 41221's Avatar
Is it leaking from the front, or from the back? If its the back, I bet its the rear cover, which is held on by 3 10mm bolts torqued to something like 2 ftlbs... its a VERY common place to have leak. Before you go too far, you might check that really quick.
And PLEASE stay away from that mechanic from now on... those are the sort that seem to always find more expensive things *wrong* with your car. $400 for an oil pressure sender is criminal. I did mine myself in about 15 minutes.
Regards,
Old 09-24-2003, 12:06 AM
Mike Buck
Mike Buck's Avatar
Default Re: Changing a leaking cam cover gasket-Guess how much!?
Originally posted by AndyK
Where do I get a short cam cover bolt (mine's stripped),
any picture of this? I'll send you the one's off my parts car. Cam cover is in the trunk in a million pieces, but I can probably find the bolts in there somewhere
Old 09-24-2003, 12:19 AM
Riff
Riff's Avatar
Andy-
I believe the leaks most often occur at the elevation transitions on the cover/head . When you re-install the gasket, a little RTV at those corners should stop additional leaking. I did this when I re-used my gasket ~50K ago and still dry.
HTH,
Old 09-24-2003, 01:54 AM
Operator
Operator's Avatar
seriously, you keep going down this leaky path and you are going to have an empty wallet faster than you can say FOR SALE
either that or your wife will just kill you before it goes that far.
go somewhere else with the car, i think they're breaking it everytime they "fix" something else. ?? its possible...
Old 09-24-2003, 01:58 AM
PorscheG96
PorscheG96's Avatar
For anyone in the SF Bay Area 'German Auto Kraft' does this exact same thing. $250 is what you agree to for the job but that's only for the diagnosis...then it's hundreds more for the repair with cheap parts that fail 1 month after warranty is expired.
Old 09-24-2003, 02:09 AM
Dmitry S.
Dmitry S.'s Avatar
G96, where in the Bay Area do you live?
Old 09-24-2003, 02:10 AM
MTM
MTM's Avatar
PorscheG96, where do you usually take your car? I've been going to CT Automotive in Campbell.
Old 09-24-2003, 03:51 AM
89magic98
In the Sink
89magic98's Avatar
So I get a call back that the leak is from the cam cover gasket, leaking down the side of the block and pooling, eventually dripping to the floor. Anyone want to take a guess at how much this place wanted to charge me to unscrew the bolts on the cam cover, replace the gasket, and screw it back together??
A mere $295!
Where do I get a short cam cover bolt (mine's stripped), and, what should I use to SEAL the gasket this time so it doesn't leak? My gasket is brand new, but since it was used, I assume I should buy another one to make sure it seats right??
Is it really that easy on an S2?
On an N/A, I think you have to take the timing belt off, which would explain a price in that range.
Kevin
Old 09-24-2003, 05:25 AM
Legoland951
Legoland951's Avatar
Most mechanics will take the cam tower off along with the timing belt and balance shaft belt. Its more work than taking the "cover" off because its not just a cover. It is a housing containing the lifters and the cam so when you remove it, do not mess up the order of the lifters and you will have to retime your car. I have been able to replace the camtower seal ($7 dollar part) without removing the timing belt to save a lot of time but I don't think most mechanics do it that way. Just think of it as a timing belt replacement without the cost of parts and more labor. This will explain the mere $295 to replace your camtower gasket. Too bad you don't live in S. Ca. because we may have a gathering to replace t belts and camtower gaskets.
Old 09-24-2003, 11:32 AM
AndyK
AndyK's Avatar
Default VALVE Cover gasket
I meant Valve cover gasket, not cam cover. Sorry! That makes it even WORSE as far as a rip off goes!
Mike--Here is a photo of the bolts (you know them, I am sure)...I need a short one, like the ones on all 4 corners. The one that is stripped on mine is right under the fuel hoses--a major PITA to move those to get at the nut!Do these fuel hoses come off, or will that involve spilling gas all over the place??
Marc--Thanks for the lift offer! I'm gonna change the valve cover gasket again myself, using that RTV stuff in the corners. I don't know why it's leaking--maybe I torqued the nuts down too far, compressing the gasket too much??
The leak is from the bottom of the gasket...
Old 09-24-2003, 12:12 PM
Legoland951
Sorry, I didn't see the SOLD part for the 88 944 n/a and thought you were refering to an 8v engine.
Old 09-24-2003, 02:16 PM
Riff
Riff's Avatar
Andy-
I think the bolts are dealer only or might get some from a recycler.
You can remove the cam cover without removing the fuel lines. It will wiggle out, just don't try to force anything.
You mention that the bolt is stripped as in the head of the bolt is rounded out? The torque spec on thes things is very light, like 6 or 7 ft-lbs. Too much and they snap!
HTH.
Quick Reply: Changing a leaking cam cover gasket-Guess how much!?
