944S Camshafts
Folks - rebuilding a 944S 16v motor . . . . what a mess.
Anyways. The gears on the camshafts are broken apart (found them plugging up the oil pickup!)
Does anyone have a source for new camshafts for these cars? OEM or slightly upgraded?
I believe the S2 head may be similar/the same and those cams might work? Looking at specs they seemed quite a bit more aggressive.
I already spoke with Web - they regrind my existing cams, which aren't reusable.
Don't know if the heads are the same, but here is a whole S2 head for sale for a very good deal I think.
http://forums.pelicanparts.com/porsc...ead-850-a.html
RSbarn can put new sprockets on your cams for around $650 i want to say.
Hot s2 cams would work, but the S exhaust cam is already a bit hotter than the S2's so it may not be a huge gain on that side. Don't be tempted by 968 cams, they have a different tooth count and will not work. Replace the cam pads while you have the cams out of the car.
http://www.rsbarn.com/catalog/index....products_id=85
