1985 Engine Sound Help Needed
So, the car that I bought from my son on Ebay arrived today. It is SO not as the previous owner described. It's not right on the outside or the inside. Here is a link to a video of the sound I posted about a couple of weeks ago. Can anyone help with what it might be? It starts up, will run (even though I have not driven it except to get it off the shipper's trailer), but makes a horrible, intermittent "metal" sound. Thoughts anyone?
https://www.youtube.com/watch?v=ApEz...ature=youtu.be
Horrid. I've heard rod knock that sounds better. These cars are smooth and quiet when running right.
Pull the upper half belt cover and see that the cam and balance shaft belts are in place. Get working on a refund, too.
Removed the upper and lower covers, cut off the balance shaft belt, and the link is a video of what the engine sounded like. https://www.youtube.com/watch?v=RpQR...ature=youtu.be
Here are a couple of pics of what things looked like. I'd love to know what your thoughts are as to what the problem is. Thanks everyone!
Well the tensioner in the second picture (center left) is camed out toward the housing and should be down toward the other roller. With that said I don't think that caused this but it is pushing the belt up too high toward the housing and water pump. I bet if you started spinning the upper balance sprocket, lower sprocket, or center sprocket one of them will no spin. No way a toothed belt can chunk like that without something being stationary in the system. What spooks me is it is t inside teeth which only touch the upper and lower sprockets as well as the one on the crank (and we know it has to be spinning
)Looks like you have some leaks to attend to as well.
