Rod bearing replacement Preparation and Oil Pan Baffle insert replacement
Proprietoristicly Refined
I am reposting the information I put on Pelican.
http://forums.pelicanparts.com/porsc...-part-1-a.html
The additional information is about the Oil Pan Baffle Insert replacement.
Techno Duck did a very good DIY and showed the Oil Pan Baffle installed.
https://rennlist.com/forums/944-turb...pictorial.html
Skip at Paragon Products mentions to install the Oil Pan Baffle but fails to explain why it should be changed.
http://web.archive.org/web/200411251...x_v2&id=70&c=4
Clarks- Garage has a very basic DIY
The OEM Oil Pan Baffle Insert is old and brittle. The pictures of cracked inserts are many. The Insert will break if you fail to carefully install the oil pan correctly while lifting over the oil pickup tube.
Failure to have a replacement will cost days of delay.
![Name: Cracked oil pan baffe credit to jsneeb 944online.jpg
Size: 329.2 KB](https://rennlist.com/forums/attachments/924-931-944-951-968-forum/956018d1437403926-rod-bearing-replacement-preparation-and-oil-pan-baffle-insert-replacement-cracked-oil-pan-baffe-credit-to-jsneeb-944online.jpg)
Credit to jsneeb
My conclusion in researching the oil pan insert is that it should be changed.
Anyone that pushes his car and wants to improve oil flow should install the updated oil pan baffle insert that fits in all motors according to Lindsay Racing.
The owners that want to keep the car for many years should just change it when doing the rod bearing maintenance.
J_AZ
Credit to jsneeb
J_AZ
