Weird compression test results = head gasket failure??
I had an issue last weekend at the track with my 4psi supercharged 944. The car ran amazing but I was having major crankcase venting issues. I was blowing a large quantity of oil out the dipstick hole. I tried a few different way to relieve it but was unsuccessful. So I built by own baffled catch can, installed it and went for a drive. The car isn't running well anymore(wasn't on the way home from the track either). My A/F readings are off, the car won't run in closed loop anymore(might be a fouled O2 sensor, not sure) and it just feels off. I took it for a drive and emptied the catch can when I got home and there was about an 1/8th of a litre in there(after 20 mins of driving). Also the car was running hotter than usual and being that it isn't hot out today that's cause for concern too. Thats a lot of oil for a short drive. So I brought it home and did a compression test. Here are the results:
Cyl. 1 - 160
Cyl. 2 - 195
Cyl. 3 - 160
Cyl. 4 - 160
What is up with cylinder 2?
The spark plugs are all pretty much the same, maybe looking a touch on the light side but I did lean out the tune a little for the drive home. It was still showing under 14.7 minimum on the AFR gauge and going rich at WOT.
Also there is oil at the base of the head under the intake manifold side leading me to believe the head gasket is gone, but in my experience, the coolant or oil would show signs.
I'm stumped. Based on what I am seeing I'm thinking head gasket, but why the increased cylinder pressure in #2?
Thoughts?
Cyl. 1 - 160
Cyl. 2 - 195
Cyl. 3 - 160
Cyl. 4 - 160
Thoughts?
I am wondering if I don't have oil leaking into that cylinder somehow and it's giving me artificially high numbers. But why would I have oil in that cylinder?
I'm going to pull the cylinder head off tonight and see what's up? I'm just trying to prep myself before hand if I only need a head gasket or a complete rebuild?
I wonder if you have excessive carbon build up, or something that is displacing some of the cylinder head volume... this would give you higher compression numbers?
but the head could of been shaved to raise the compression ratio....we did that on the 44 turbos....still think the leakdown would show something that would lead to pulling the head....
