Help me design my head
The pictures below show my modifed cylinderhead, valve seats and valves. Simple hotrodders old school workmanship, proven and effective.
It doesn't cost much, it's just a fine tuning of the existing material.
1.) Valve seats with multi radius cut, blended with the rest of the port (+ top cut),
2.) Valves with radiused back cut (helps low lift flow)
3.) Widened valve seat ring
4.) Port matching
5.) MLS HEAD GASKET, C4272-030 (0.3 inch)
Additionally my car got a camshaft with more lift, NA-Tune, a extruded honed intake and a 4-1 header.
In 5th gear the car is running easily into the rev limiter (Euro Spec gearbox). So it seems, it was worth the effort.
Professional Hoon
I have a pretty heavily worked head on my block.
Stock head:
Worked head (3.2mm oversize intake valves and ported)
With the right cam for an N/A you should see a decent gain.
Professional Hoon
Check this out. There's a thread on it on the turbo section. But this is better on the info all in 1 spot.
http://www.refresh951.com/HFHead.htm
