Since nobody bothers to use the classified ads...
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
I have some stuff for sale off of my 88 924S plus some other parts as well.
- Early NA intake manifold
- Early throttle body
- Three Spoke wheel - black, good condition
- extra 3 spoke horn pad
- Complete power steering rack, pump and lines off my 924S. Worked perfect prior to removal.
- two drivers side and one passenger side mirror - Black, fair to good, wiring so-so.
- outside mirror switch
- lower half of NA airbox and K&N filter to match
- Outside door handle - 86 drivers side. good condition
- Drivers side door window glass
- Window motor/regulator
- 924 rear emblem
- 15 inch wheels for a VW GTI - 5 spoke 4x100
- Fender Precision bass - Black, maple neck
- Inner door handle - 86, tan(?) drivers side
- Latch and stuff - drivers side door
- lower dash panel under glove box - black, perfect, early dash
Make a reasonable offer on this wonderful stuff. I can get pictures of the stuff, it may take a while though since I have to use a camera from work.
- 924 rear emblem
To bad one of my coworkers already left for Cinci, I'd have given it to him to drop off to you. How about shipping plus 10 bucks for the effort. It only has, literally, a couple thousand miles on it, but it has been in the basement for a while.
AFX,
How's $25.00 plus shipping sound? If you want it PM me with your shipping address and I'll figure out how much that will cost.
Riff,
Yes they should fit a 91 GTI as long as it has the 4x100 bolt pattern. The offset should be just fine. They aren't factory wheels mind you. The are 15x7 5 spoke and look like what you could get as an option back in 97/98. They have Faulken 195/50 15 Z rated rubber on right now. The tires are very sticky. I'll get some pictures tonight if I can get one of our cameras. I'd like to get $300 plus shipping, but a reasonable offer will certainly be entertained
Jonathan,
I don't know for sure if it will fit your car or not. My PET isn't installed right now so I can't reference it. Neither the rack nor the pump leak a drop. The hoses and lines are all available, but I thing the rubber bits should be replaced.
Riff,
Jonathan,
