Big Red's or 944S2 Brakes
Aren't all 944 abnormal? That's why "we" drive them. Actually I'll be doing a lot of TT track events and am worried about break fade with the stock calibers. I always thought larger was better or why did Dr. Porsche add the "big" breaks to the 1988 plus turbos?
Chow.
Chow.
Originally posted by Jonas Goldsmith
OK 2 things....
1. there was no S2 in 88... (can't believe no one cought that)
OK 2 things....
Wow so much info, very much appreciated. Again long TTs with minimum break fade would be the optimum. (Option 090: Turbo motor may be inserted)
Is it pads or the whole systems. So far C-tech pads have worked great but i'm looking for that extra 10ths.
Hacker, the 951 caliper fit the rear of an 87 NA? I have an 88 NA, I would like to go with more brakes. I thought the NA control arm in the rear had a different mounting than the 951? Did you use the rear 951 calipers on the rear or front 951 caliper all the way? TIA
Andy, email me, I'll give you the lowdown on all that. You saw my car last weekend with the brake upgrades so I have a good list of everything you need.
Tifo
Tifo
Originally posted by Karl Glynn
The M030 versions of the 944S2/951/968 used the same brakes as the 928 S4. These were also used by the 951S ('88 & '89).
