Best easy way to paint calipers?
TarHeel 944S, if you want to do 'em in red, here's a pic of calipers on an early car done in red. Maybe a little "rice" but behind the Fuchs it's actually pretty subtle.
Just clean up calipers and rotor hats with brake cleaner and spray or brush with High Temp paint. Paint is durable if you don't bang the caliper removing/installing the wheel.
You could do them in silver but IMO that's a little too subtle!
Originally posted by HY M8NC
car slave-I like the aluminum look myself. I painted mine with a high heat aluminum color paint. I couldn't evenly clean the calipers enough so that it looked good. If you get them blasted, it might work better. I just took mine apart, wire brushed them, cleaned/masked and sprayed.
If I could have anything I wanted-it would be the gold anodized color of the current Brembo's (on the 350Z).
Do you have a picture of your rotors with the wheels on?
Also, what paint did you use?
Thanks!
-Kevin
