Headlight motor electrical question
My headlights won't come up when I put on the lights.
I've narrowed the problem down, turns out the Red/Blue supply wire doesn't supply current at the connection. It does have 12 volts at the fuse (#2, 25 amps) but it doesn't supply power at the headlight motor connection anymore.
If I understand correctly, the red/blue supply wire runs from the fuse-box to the headlight motor. So there should be a breech in the cable somewhere.
Where is the supply wire most likely to break? If anybody had this problem before I would like to hear were they found the breach.
