2001 996 Turbo Wheels on a 951
They should fit on later offset 944s as far as I know.
Basic Sponsor
87& up will fit fine
Freedom Enthusiast
235/40 ZR 18 X 8 50et front
295/30 ZR 18 X 11 45et back
These will fit early and late offset. Fitting on early offset is easier than late offset.
You will need spacers front and rear for early offset. You may need to roll the rear fenders and even make a little bit of room on the inside fender wells in the rear.
For the front, you will need spacers to clear the front wheel bearing dust caps.
For late offset, you will need front spacers to clear the wheel bearing dust caps. You will also need to do some very aggressive fender rolling/stretching.
Red 951 = Early offset
White 944 S2 Cab = late offset
azbanks,
I just picked up a set of the exact wheel sizes you mention for my early offset 86 951. I will be buying spacers, rolling my fenders and buying new rear tires.
I assume I need a 25 mm spacer on the front, right?
Do you know what size spacer is correct for the rear?
Also, how wide or narrow of rear tires should I buy? Will a 265 or 275 wide tire help with avoiding rubbing?
Thanks in advance.
Thanks in advance.
Freedom Enthusiast
azbanks,
Thanks in advance.
Thanks in advance.
Yes, they will fit.
I test fit the 11s last night. I found that if I shave a couple mm of off 1 spring bolt past the nut and a couple mm off of a piece of metal sticking out, I could fit them with only 3 mm spacers.
15 mm spacers seem like they would need the fenders rolled and stick out pretty far. I may go with bigger spacers later if I ever swap out the studs and roll the fender.
I also secured the line tighter to the arm which keeps it off the wheel. I am going to try it for a little while and check everything. Worst case I put bigger spacers on and roll the fenders.
