Rennbay Ball Joints Question Travis
I need to do my control arms soon is the kit for both sides? Also do you need any special tools to do the rebuild? One more last thing when buy the 100$ kit that you can replace them whenever you want for 15$ later does that include when I sell my car and by another one will that be still 15$ or 100$ for the whole kit? Thanks ahead of time.
Seb
Seb
The install does not take any special tools. There is a great tutorial on the "tutorials" page on www.rennbay.com .
Both the standard and lifetime kits on there rebuild both arms. You should always replace both at the same time.
The lifetime replacement works like this. When you feel you need to replace the bushings you will log on to a special web page that is given out only with the kit. You enter your replacement ID that came with your kit and hit the buy button ($15). When I get the order in for replacements I will send you out a new set (both sides). When you get the new ones put in you MUST send back your worn ones. When the worn ones come back in I check you off to be eligible for your next replacement. The lifetime replacement bushings are also blue so they can be distinguished from the standard ones.
And if for some reason you do sell your car and buy another I will be willing to work out a more than reasonable discount on a second complete set and still allow you to keep the lifetime replacement plan for the new car.
Thanks Travis I will be placing an order sooner or later depend on how my law fees go and things. Thanks for replying so quickly.
Seb
Seb
