how the frick do you install a new window?
i cant get it to go on the little roller things? do i need to unscrew the actuator arm things and put them on then screw it back to the door?
Big thirst, Sore Thumbs
Napoleon
Napoleon
![](https://rennlist.com/forums/images/ranks/veteran_marine_corp.png)
You need to do it by putting the rear in with the front tilted down and outside of it;s rail, then finnangle it nose down until you can pop it into the front rail and than level it horizontally.
Taint fun, I'll tell you that.
I had to loosen the window regulator and shift it around in order to get the window in the tracks and scissor arm rollers in the lower rail on the bottom of the glass.
Good luck.
Good luck.
Napoleon
Napoleon
Oh sorry. Took the cold shower to mean something else.
Remembering a bit. The rear most rail is removable, pop that puppy off it allows you to tilt the window more.
really. dange i wish i would have figured that out before i quit for the night. at least i got it to were i ca close the window. its jsut kinda sitting on the front roller for now. its wedged int here so it wont fall off while driving. i jsut meant its really really hot and sticky outside i didnt veen think about the other meaning of the cold shower thing.
Napoleon
Napoleon
Try loosening it first.
Once you figure it out it's quick. I remember replacing one of those buttons in 20 minutes once.
