Clock light question
Hmm
My search turned up that the headlight switch bulb is meant to be 0.3W (confirmed by PET), but these bulbs look like they may be 1.2W
Not sure how much of a bad thing it is.
Martin
Martin
Anyone got a pic of the back of the clock.
On mine there's a 4 pin connector, and then a black protrusion (sticky-out thing) next that look like it has contacts, but hasn't got any wires to it.
It says OSRAM so I am fairly confident it holds the bulb. Any clues.
If this is the right thing...how does it come out.....
Martin
Martin
Thanks MaxNu, I now have a working light in the clock.
Twisted the bulb holder out, pried the bulb and contacts out, and carefully replaced the bulb so that legs poked out of the holder. Slid the two metal contacts back in the holder, bending the legs back against the contact.
Job done.
Thanks for your help everyone. Now to put it back together, but I'll probably have to take the glove box off in the process to put the internal temp sensor tubing back on.
Thanks again. (Now to tackle the light behind the headlight switch - though I may not bother as I know where it is and from my driving position is hidden enough anyway)
Martin
Job done.
Martin
Hmm, light in the headlight switch? I had no idea, I guess that means mine is burnt out, along with about 15 other bulbs in the car, my clock light is odd, it only seems to work when I don't need it, every time I look at it, the light is out, but whenever my GF looks at it, it's on! Stupid clock is playing favorites!
