Tech question: getting the best ride from the torsion bar rear suspension
#32
One of the components frequently overlooked in the search for improved ride quality is the seat. However the seat "suspends" the occupant and has a much more important role in perceived ride quality than most people realise.
Getting your seats reupholstered (including fresh foam) might give you the improvement you're after.
Cheers,
Mike
Cheers,
Mike
#33
Good point, When I bought my 951 it had lambswool seat covers. I thought they were out of place on a sports car, and certainly nothing I'd put on my car, but I really enjoyed the drive home. They were extremely comfortable! BTW, the rear Koni's were set on full soft, too.
#34
Rainman
bumping this..
are the OEM-spec Koni shocks really that good compared to Boge/Sachs?
With bushings I will replace rear shocks. And am 99% sure I will switch to 26mm torsion bars.
I have a pair of early Konis for the rear that need a rebuild anyways...will it be worth the extra $100-150?
Remember, I am only asking in terms of ride quality, not handling.
#35
Rainman
bit of an update - car handles much much sharper now, it used to understeer like a cruise ship but now takes corners exactly as i want them to. will kick the tail sideways with some throttle...much better.
the tradeoff is a bumpier ride - the new bushings helped some but the stiffer bars make things very bouncy on bumpy roads. new shocks will help of course, but i can't imagine how people are running 28-30mm (250-300lb/in) bars on street cars, unless your streets are smooth as glass asphalt. here in the land of concrete expansion joints those stiff bars would break your back.
