H2O accumulation
I've noticed recently a small amount of water accumulating under the carpeting by the parking brake. Isn't there all the time after rain, might only be after driving. Any idea what might be leaking? Is it the window or could it be coming from underneath? Doesn't seem like a common problem, but I have notice that some change had fallen in there in the past and it is starting to look a little corroded and I don't want my car to do the same.
Coming in along the top of the door. Most likely the corner area. This runs down between the door seal and the jamb then accumulates at the bottom jamb. A good left hand corner and the water sloshes over into the cab.
The three drain holes for the inner door window area are outside the door seal a the bottom.
Replace the door seal and/or adjust the door.
