do i need an oil cooler alignment tool if the relief valve is still in the housing?
I never notice, anyway
when i took the oil cooler housing off, i left the relief valve in it. can i just put the housing back on with the relief valve in it and completely forget about an alignment tool?
What I did when I replaced the housing was use the PRV itself to align the housing. I found that the tool was useless, it was too small and the PRV actually bound up in the housing when installing. I used the PRV itself and all worked great.
Dal.
Dal.
