Temp Control Sender
My '86 951 has been stumbling, cuttign out at idle, and running rough. I am changing the fuel filter becasue maybe it is not getting fuel, but then I read some stuff about the Temp Control Sender for the DME, and now I'm thinking maybe that is my problem. I read that if it is messed up, your car runs to rich or too lean. When I dscovered this problem I was driving the car and I smelt a burning firecracker smell, kinda like sulfur. Does this smell have anything to do with too rich or too lean?
Mike
Mike
If the temp sender is not the problem, it should be a problem with the fuel delivery, so I should check fuel pump, filter9I'm actually changing that out tonite), and fuel pressure? Hopefully the temp sender does it.
Make sure your grounds are clean, first.
The connection at the sender was apparently a bigger problem on the early cars than series 2.
My guage bounces due to dirty contacts between the circuit board in the instrument cluster and the guage itself. It often pegs out, but a smack to the dash puts it right for a while. It was rock-solid (at one needle-width above center) for a couple months after I unplugged and replugged it into the cluster.
