Are all clutch slave cylinders rebuildable?
I pulled the slave in my new 86, it was junk, the fluid that came out was black. Good news is the clutch looks great! The slave is an FTE brand. I pulled the plunger out and removed the seal, then pulled the star shaped ring out, but the piston isnt coming out and I dont know how to remove it so I can examine the bore. Are all the slaves rebuildable, or only certain brands? Am I doing something wrong? It was my understanding that with the retaining ring out, the spring should just push the piston out, after which I can remove the spring and examine/hone the bore. I dont want to drop 85 bucks on another slave if I can rebuild mine for 20.
Edit: Still curious on this but I just took my chances on what is probably a made in china remanufactured slave, it was only 22 bucks on ebay, literally cheaper than a rebuild kit so I figure if it works, great, if not, I'm only out 30 minutes of my time to replace it again. I'll let you guys know how it goes.
Thanks, that's what I figured. I'll go ahead and rebuild this one and have a spare if my china slave fails. Also, while getting the bleeder out I pretty much ruined the nut, are the bleeders on the slave just standard sized ones like you'd find on calipers? Easy/cheap to source?
