Cruise control question
Old 08-08-2003, 12:49 PM
Tom R.
Tom R.'s Avatar
Default Cruise control question
The board that goes bad, is it in the servo?
Old 08-08-2003, 12:53 PM
Wormhole
Wormhole's Avatar
No. I think it's in the brain under the dash by the hood release.
Old 08-08-2003, 01:10 PM
Mark Hubley
Mark Hubley's Avatar
Stick your head under the driver's side dash, and look above where your left shin would be. There is an aluminum box about the size of a VHS tape. There are two wirin harnesses attached (both next to each other facing the rear of the car), and the box is held in place by two 12 mm nuts (one at the rear and one at the front). The nut at the front can be a real bitch to get at. Use a flashlight to get a look at where it is.
Old 08-08-2003, 01:36 PM
Chris_924s
Nerd Herder
Chris_924s's Avatar
Tom- that's exactly where it will be on the late 944's.. above the hood release.
Old 08-08-2003, 02:00 PM
AndyK
AndyK's Avatar
My cruise control isn't working. I have a receipt from the p/o saying "needs new cruise control brain". Is that what you're fixing Tom?? How much for the repair part?
Old 08-08-2003, 02:06 PM
Tom R.
Tom R.'s Avatar
i bid on what was listed as a "servo" on ebay thinking i could swap that part.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426871687
if it is the right part don't bid against me. i will donate my old one to whoever is soldering them as a core.
if it is the wrong part, and someone needs a servo, dont bid against me, i will have it shipped to you for what i get it for. unless it is the wrong part, and i get outbid.
Old 08-08-2003, 02:09 PM
Tom R.
Tom R.'s Avatar
andy,
you probably have to get your board re soldered check the archives.
Old 08-08-2003, 04:14 PM
Mark Hubley
I'm pretty sure the "servo" is located under the hood, just in front of the battery compartment. I'm also 99% sure that the servo is not causing your problems. The problem is the "brain" in the box above the hood release.
I believe a new cruise brain from a dealer will run you about $500. Some Rennlisters have fixed their cruise brains by resoldering connections on the circuit board. Search for "cruise control re-works" and you'll come up with a thread started by SidViscous. He fixed my cruise brain with the resolder method. Perhaps you can try the fix yourself, or find someone who can do it for you. You might also try used parts dealers to see if you can get a functional used cruise brain.
Mark
Old 08-08-2003, 05:18 PM
triscadek
triscadek's Avatar
The servo is is front of the battery and is rarely what goes bad, the control box under the dash is almost always the culprit,I took mine to a CB radio repair shop and had it resoldered fo $10. Works like a charm now.
Come to think of it I don't think that I've ever read of the servo going bad , but I'm sure they do.
Old 08-08-2003, 05:22 PM
AndyK
AndyK's Avatar
How do you "RE" solder? Just heat all the joints with a soldering iron, let dry, re-install and check?
Ken D
Ken D's Avatar
I think Sid Viscous is soldering these as a "side business."
Old 08-08-2003, 05:26 PM
Tom R.
Tom R.'s Avatar
i e mailed the seller and asked him to confirm the cruise control parts includes the brain. lets see what happens, the worst is i retract my bid citing a brain fart. mistook servo to mean brain.
Old 08-08-2003, 05:35 PM
Mark Hubley
Tom,
Does that mean the brain inside your head needs re-soldering too???
Old 08-08-2003, 05:37 PM
Ken D
Ken D's Avatar
I don't think Sid can help him with that.
Old 08-08-2003, 05:51 PM
Peckster
Peckster's Avatar
Give him a chance, eh? Who knows, this might open up another career for Sid. Discount surgeon.
Quick Reply: Cruise control question
