Adapting 2-bolt mid pipe flange to a 3-bolt pipe
I'm sure this could be solved with big enough washers, but am wondering if anyone has a more elegant/less jerry-rigged solution.
I want to try out a muffler that's already welded to a 944 aft pipe (or whatever you call that tubing between the cat and the muffler). Problem is, it's a triangular 3-bolt flange and the mid pipe/resonator has an oval-shaped 2-bolt flange.
versus
Any wisdom?
versus
Any wisdom?
If I like the new one, I'll bust out the grinder and hit up an exhaust shop.
I like the setup, I just want to have a second option I can put up in a couple minutes. I'll bring it up with me
