Doing the rear main seal. Should I install new clutch?
When I get my car back from my mechanic I plan on taking a weekend and replacing my rear main seal. Thing is I have 10K on a new clutch, should I put a new 600 dollar clutch kit in?
Christian
Christian
If you only have 10K on the clutch it would be a waste of money to change it out. Make sure the pilot & throwout bearings are good. If your slave cylinder is original you may want to do that.
I would replace the disc. It is not 600 the fibre disc has absorbed some oil if it is wet at all... The metal from the flywheel and the pressure plate shouold be ok.. the cost of the disc is not all that much... MY 2 cents
