What does fuse 17 do?
I've been trying to debug my non working a/c system and tracing the reason why my compressor would not engage. In the process, I was able to jump the compressor by adding 12v directly to the pressure switch so i thought the relay was the problem, which is was not ($50 down the drain, but we live and learn). Turns out fuse 17 (heater control) was blown. It's a 7.5amp fuse which I replaced. After about 10 minutes, that fuse blew.
Aside from the a/c switch, what else is on that circuit that could cause fuse 17 to blow?
Short w/ac compressor?
Devia (11-16-2019)
The relay is there to open power from the AC Controller to the AC compressor clutch if the engine overheats. The AC controller DOES drive the AC compressor clutch and a bad clutch will blow fuse 17. Check the resistance of the wire going to the clutch to ground (unplug). If it is less then 3 ohms, you have problems.
