n/a head potential
Sleeve the block and fit a stroked 3.0 crank to get you to around 3.2, fit some HC pistons, better cam, better engine management, 48mm intake valves, flow intake & head and that 2.5 8v head should net you over 250.
Headwork alone, idk.
Custom work on the whole engine, from internals to management, can net about a max of 275 fwhp.
No, I don't have the dyno sheets to prove it.
...........Yea, I'm that guy who randomly posts in these threads claiming these numbers. I'm sure no one believes it anyway, so whatever!![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
It's easy to spend $10k building an engine that's still a 2.5 (legal for 944 cup racing) and only get 145 whp - which would be about 175 hp at the crank.
If costs rise exponentially for this kind of performance, I can only imagine what it would take to get another 100 hp.
Yes the 968 head flows better, but we are not aiming for 350+ hp engine here, just the best surroundings to make max hp out of a 2.5na head.
Still quite a pointless excersize, building an engine around the limitations of the cylinder head, just a bit of tech fun! You are basically trying to build a big air pump around an air restrictor.
I love the idea of a fire breathing 4 popper. I think Milledge make 230 hp (fw I assume) outta the 2.5... but that's probably $25000+ us.
Thanks for the responses. Please continue to add! I'll just read & learn.
Since my original enquiry I have decided to (after the fall autox season)
-get turbo valve springs.
-port & polish
-47mm intake valves
-MAF
-fabricate ram air duct
Also with the head off, will measure. Considering shaving the head more & fly cutting the pistons, but knock is already a concern (with 10.2:1 !!!).
-port & polish
-47mm intake valves
-MAF
Here is the result off a couple of days in the workshop.
My car is a -82 944 n/a. Engine from -88. Euro spec.
Portet head. (Home made)
Balance shaft delete.
280* DBilas camshaft.
Turbo valve springs.
Tommibillets cam adj.
Dansk Rear tail pipe.
Stil on original DME and MAF. (Megasquirt comming soon)
Dyno result before: 97 kw. (132 hk) on Wheels at 6000 rpm.
Dyno result after: 117 kw. (159 hk) on weehls at 6200 rpm.
At 2000 rpm. + 5 kw.
At 3000 rpm. + 7 kw.
At 4000 rpm. +10 kw.
At 5000 rpm. + 14 kw.
Regards Per
Regards Per
idk, I think the 968 leaves a lot on the table. An extra 200cc, bump that compression up to 12:1, a decent engine management with sequential direct ignition like Electomotive. Extrude hone the intake, flow the 2.5 head with larger intake valves, imo it would be quite close.
Yes the 968 head flows better, but we are not aiming for 350+ hp engine here, just the best surroundings to make max hp out of a 2.5na head.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
944 S2 280 bhp upgrade (click below)
https://rennlist.com/forums/944-and-...l#post12169976
Regards Per
Regards Per
Before: 130 HP/After: 159 HP at wheels. Big improvements for that old Porsche!
HUGE THANKS Per for providing real dyno stats. So the '88 is about 162 HP normally (when new) so we lose 30 HP through the drive train in these cars. Good to know!
-port & polish
-47mm intake valves
-MAF
-port & polish
-47mm intake valves
-MAF
You'll still get more just by bolting a 944S head onto your motor or finding an S motor, it flows considerably better than even a ported 8v head and is a bolt on. You just need a set of S pistons and an S or S2 intake/header and your off. 188HP to start with and 10.9:1 Compression. My 944S with 170k miles on it put down 160hp to the wheels (corrected for altitude). It gained 10hp with the MAF/tune i was testing at the time.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
I to would like an S.
But her in Denmark, they are wery rare, and expensive. Spareparts are also wery hart to come by.
8 valves are allover the place. Only problem is high milage.
Regards Per
Regards Per
Head, pistons and intake + work and you are on $5k easy. You can buy complete S car for 5k.
Voith is right though, buying an S might even be a better option, i sold mine for 5k.
