944 S2 280 bhp upgrade
Hi, I don't know if this will be of interest to you all, but I'll post it anyway.
I have just built this engine for a customer for a race series where he has to
run the standard inlet plenium. I've done a few internal changes, pistons, rods, camshafts, inlet valves, head porting and compression ratio.
We have had it on the dyno today and these are the results.
Cheers Tim
Cheers Tim
Hi, We are running a 968 inlet valve. The engine is going in a 944 racecar. We are not running MAF and the its map on an Omex stand alone ECU
Turbotim3,
Could you list the changes you have made to this engine?
It's quite impressive that you have been able to get both the horsepower and especially torque to the levels on your dyno sheet and it would be great if you could share what you have done.
The cams have been re-profiled to a solid lifter set up, to give more lift and duration.
Cheers Tim
