Fuel Gauge problem after cluster replacement. HELP
Hi,
Today I replaced my 1987 944 NA original instrument cluster, with a nicer one that I bought few months ago to a board member.
All gauges are working properly. Old fuel gauge was reading 1/4 tank. Then when I replaced the cluster fuel gauge started to read 3/4 tank. I drove few minutes and take some hard turns to see if the sender was out of place but gauge stayed rock solid at 3/4.
I proceed to add 20 liters of gas, and now gauge is reading steady 4/4. I drove few miles to see if gauge went down, but nothing happens.
There's any chance gauge is out of calibration? Any help is welcome.
Sender was reding 20.1, so I make the bench test at that same ohm reading. As soon as I reconnected it started working perfectly.
