Any one try this k26 turbo rebuild kit?
Old 05-02-2014 | 02:43 PM
Alex Sol's Avatar
Alex Sol
Default Any one try this k26 turbo rebuild kit?
http://www.ebay.com/itm/944-Porsche-...-/251513577539
says it only works on the 1989 which is the k26/#8 vs the k26/#6 that most of us have.
any special tools required?
must be a reason why they charge $500-650 for rebuilt...
Old 05-02-2014 | 03:33 PM
Darwantae951's Avatar
Darwantae951
Just me, but I would leave it up to someone familiar with the process. Are you planning to do the work and the have a shop check balance?
Old 05-02-2014 | 04:51 PM
mpankau's Avatar
mpankau
I rebuilt mine myself about 6 months ago. It was not terrible, just had a lot of end play. I heard bad things about the kits on ebay, I got my kit from these guys: http://gpopshop.com/. I called and talked to them, they hooked me up with the right kit for about $120 and comes with instructions. It was not really to tough either, if you are mechanically strong. This was my first turbo too. Mine still works great and has 2,700 miles on it now, and counting. I have the turbo enhancer on it too and it will pull about 15 lbs of boost.
Link to my build: http://944online.com/cgi-bin/yabb2/Y...num=1377294100
Old 05-02-2014 | 05:40 PM
Alex Sol's Avatar
Alex Sol
thanks for the contact...
G-Pop Shop
22349 W War Eagle Rd
Springdale, AR 72764
i'm a little wary of the ebay guys too...
thanks mpankau for the link...
how long does it take assuming you have the turbo on the bench already?
Old 05-02-2014 | 05:45 PM
turboS_swede's Avatar
turboS_swede
They aren't hard to rebuild and if you're careful you can save the need to rebalance the assembly if you are careful with the disassembly and reassembly.
However, if you're concerned, many places will balance a turbo for you, check the local listings for diesel repair shops or you can send it to a turbo shop for a quick balance for a reasonable cost.
What you're paying for with a turbo rebuild is shop time and labor. Why pay for that when you can pull it apart, clean it, replace the worn parts and seals? If you pull it apart and find it is hosed completely, then you're only out a little time and you can track down another turbo to freshen up rather than get the "call"
Old 05-02-2014 | 06:09 PM
Alex Sol's Avatar
Alex Sol
great advice swede. we actually have a turbo rebuilder next door to us!! haha but want to learn also. not just learn to write cheques if you know what i mean.
thanks for the advise and will check for balance. neighbor showed me how they do it.. very accurate.
there is a little play and not enough to worry about but concern is all the oil
Old 05-02-2014 | 06:12 PM
Alex Sol's Avatar
Alex Sol
most important question: will it stop the oil leaking and blowing all over the intake / intercooler / throttle body...
Old 05-02-2014 | 06:15 PM
turboS_swede
It did on mine. Mine was visibly decreasing the mosquito population prior to the rebuild.
That said, it wouldn't hurt to do a leak down on the engine to make sure it isn't a ring or piston issue.
Old 05-05-2014 | 11:43 PM
Alex Sol's Avatar
Alex Sol
mine has a hiccup like the fuel is temporarily cut off then blasts out a black puff of smoke... kinda james bond like... but really not nice. will likely order from gpopshop. they answer emails and give advise... gotta be better than ebay site that doesn't allow you to send emails...
Quick Reply: Any one try this k26 turbo rebuild kit?
