Can you change the engine to firewall coolant hoses with the engine in place?
944 turbo - I have the intake, exhaust manifolds, crossover pipe, turbo, AOS and a few other pieces removed. Will be pulling the starter soon as well.
I can only see one water hose which goes from the hard pipe above the exhaust manifolds to the firewall, pretty sure I can get at that one.
I'm told there are two more hoses, but I can't even see them yet with all the wiring and vacuum stuff in the way.
Is it possible to replace these without pulling the engine? I have replacement hoses as part of my silicone hose kit, and wondering how much other stuff has to come off to get to them.
Thank you.
Thank you.
It's a pain to reach in there, but it is doable. On the early cars the hose clamps are easily reachable from the passenger footwell, so don't think you have to do everything from the engine bay. Took me a while to figure that one out.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Hi, A WYIT is to go ahead and change out the Heater Control Valve. It is much easier while the Intake Manifold is removed. I would not replace with a used part.
Cheers,
Larry
Cheers,
Larry
Replace the plastic heater control valve with a metal one while you're in there.
Here is the old thread about it. https://rennlist.com/forums/944-turb...an-happen.html
+1 for replacing the heater control valve. Be aware that when it fails, it will just burst into 2 pieces with no warning and dump all your coolant, and possibly get some into the clutch through the inspection hole in the bellhousing!
Sounds like a plan. If I go for the metal audi part, is it there any temperature controlled aspect to this or does the vacuum line connect to the heater controls and simply open or close the valve?
So glad you guys pointed this out too, I will be sure to cover the inspection hole before I remove the hoses.
