Fuel injector Problems
Old 07-30-2003 | 05:30 PM
44mag's Avatar
44mag
Default Fuel injector Problems
I looks as if one, maybe two of my fuel injectors are leaking slightly right by the head, has anyone experienced this problem, and is it something I could fix myself, I think it may be a messed up or improperly position seal. What do you guys think?
Old 07-30-2003 | 05:40 PM
Travis - sflraver's Avatar
Travis - sflraver
We just got in injector seal kits. I will have them posted to Renbay.com later tonight. They are $4 per injector or $12 for a set of 4 kits (4 injectors).
Old 07-30-2003 | 08:29 PM
Travis - sflraver
There up!!!
Here's the link
http://www.rennbay.com/injectorseals.html
Old 09-12-2004 | 03:52 PM
StupEd05's Avatar
StupEd05
If the seals are bad or installed properly will it cause a no start situation. Would also stop the car from starting off of ether?
Old 09-12-2004 | 05:29 PM
Travis - sflraver
Wow, this post is over a year old....
If you just put the seals in and the car doesn't want to stay running or just crancks over with no start you probably forgot to plug the vac lines back into the FPR/FPD.
Old 09-12-2004 | 05:40 PM
StupEd05's Avatar
StupEd05
lol, I know. I like to use the search feature and tack on... sorry! Just wondering if improperly sealed injectors would cause a huge vaccuum leak and a no start cond. And yes I hooked the fpr and fpd back up. However, when this first happened I was in the Wal-Mart parking lot and the vacuum line to the FPR had become extremely brittle and at the slightest touch shattered, I was in a rush so I took the scissors and cut off some wiper fluid hose. Prolly not good enough eh? Guess I should replace that before replacing the FPR.
Quick Reply: Fuel injector Problems
