Shaking at 50 MPH
Shaking at 50 MPH
My stearing wheel starts to shake between 45 till 55. I plan to rebalance and realign tomorrow. I took out both front wheels to check out the arm bushings and they are all in fine condition. Besides unbalanced wheels, what else could cause the shaking?
I wrote in an earlier thread that I just had my tires "road force" balanced and it made ALL the difference in the world! I could usually tell when I was approaching 60 mph by the slight wheel shake but know I couldn't tell I was doing 90! Obviously there were no other issues with my vehicle though.
Umm.. I think you'll strip the aluminum lug nut before you warp the hub surface.
I know if you put it too tight, you'll know because the stud will break when you are trying to remove the lugnut.
