Questions about S2
Questions about S2
You know how the older 944's have actual bumpers with little shocks, so if you bump into something it's no big deal? What happens if you bump into something with a 944 S2?
Also, what's this light in the middle of the dashboard for? It looks like an exclamation point.
Yep, pretty much everything will trigger it... like worn out brake pads, too low oil level in the engine etc.. there should probably be some other warning light burning at the same time telling exactly what's going on.
No idea how the bumper works, sorry... better not hit anything I guess
Both the n/a / turbo and S2 actually have bumpers in the front, except the turbo/s2 have a bumper cover, which basically goes right on top of the bumper, and if it contacts anything, it has to get painted or replaced...
more expensive, but it looks way better!
Tabor, I believe my car has three different sensors:
1: Parking Brake <- when button below e-brake is not pressed
2: Brake Fluid <- sensor on cap in resorvoir
3: Brake PAD <- when sensor wire on caliper is worn away
4: ABS (Not installed in my car)
