Venturi Delete? 87 944NA
I've found a lot of discussion around this part for turbo models, but I can't find much for the NA variety. It seems peculiar to me that Pelican Parts doesn't sell the part, so I figured I'd put the question to the forums.
What's the consensus on keeping this part for NA 944s? I am replacing all hoses while I've got my intake and intake manifold out, and the venturi and associated tube are on my list.
Thanks!
Thanks!
Rainman
The NA vacuum system is pretty basic, really.
I guess all you'd really need to keep would be the signal line from the throttle body to the fuel pressure regulators, and the hose to the brake booster. Everything else can be removed/capped/plugged...
You'd have rough idle sometimes but nothing awful.
