New Character begun on 944/2
3rd Gear
Hello all
Have an 85 /2 NA 944. Seems to have sprung an oil leak just above the exhaust manifold. Standing on the passenger side of the car facing the driver side would be the far left exhaust bolts see to have oil on them and the smoke roll out from there.
1. is this the cam tower gasket?
2. How difficult is this to fix?
3. Ive looked up the parts an know the gaskets are available for the cam tower do I need the intake gaskets as well?
This is a DD right now and cant afford to have it fail on me.
Thanks in advance
Epi
Thanks in advance
Epi
I'm no expert on the 944, but sounds like valve cover gasket (maybe that's cam tower on 944. If so, it's a fairly easy job. Even when I use new gaskets, I like to use a light coating of RTV on the head surface to account for any scratches, pits, etc. from age.
In fact, if you need it done asap and don't have easy access to the gasket, just take if off, clean everything, give the head the light coat of RTV, and reinstall old gasket. Not the best solution, but I've had it work well in a pinch until I could spend more time on it.
This sounds like it might be the cork gasket at the firewall end of the cam tower cover. It's a bit tight in there but can be repaced with combination wrenches. They're either 10 or 13 mm but can't remember for sure. Make sure you are careful pulling off the end cover so you know the orientation when putting it back on. I'd spray a little paint back there so you'll see which side is up (clean with acetone and rag first so the paint'll stick). When you put the new gasket on, be careful not to overtighten it. It's cork and will smash down real easy.
3rd Gear
Thanks all
Thanks all
Need more patience with this machine, really dont want to mess with the engine , and a gasket seems harmless enough..
However taking the fuel rail and all that stuffs back off again im not looking forward to..
damn
damn
if its the cam tower don't rush...back out each bolt a little bit at a time or it will get hung up. I had every bolt out and the tower would not come off. Had to tighten them all back up and start over then it came right off.
If its your first time diving in, don't be afraid to take some photos of your progress, they come in handy.
Good luck.
Good luck.
3rd Gear
Another Character Flaw
Seems there is a water leak (rain in eastern NC go figure) dripping in the driver side footwell behind the dash. My guess is on of the cowl drains is clogged. Just had the windshield replaced in December so I'm doubting its coming in under that. Feet got nice and wet taking a right turn Saturday.
Anyone know where the cowl drains are and can they be routed out with a wire hangar or heavy gage wire to clear them??
Another Character Flaw Seems there is a water leak (rain in eastern NC go figure) dripping in the driver side footwell behind the dash. My guess is on of the cowl drains is clogged. Just had the windshield replaced in December so I'm doubting its coming in under that. Feet got nice and wet taking a right turn Saturday. Anyone know where the cowl drains are and can they be routed out with a wire hangar or heavy gage wire to clear them??
