Oil cooler housing difference.
Just want to know the difference between the 87+ late turbo housing and 86 - early turbo housing. I know for the oprv but are the housing the same ? Could I use the late housing with early oprv on a 1983 to 1986 engine ?
Thank
Thank
Rainman
IIRC there is a difference in a metal sleeve in the block for the housing. Earlier blocks have a removable sleeve with o-rings, and the later cars have a sleeve/dowel fixed into the block...could be wrong though.
