door actuator
door actuator
Hello again all, I was wondering if anyone here had or knew of where I could get a used 86 944 turbo drivers side door actuator. I had gone through the process and found one and it turned out it was from an 85 or something because it was not the same.
The part I need is the l shaped mechanism that on one end connects to the linkage from the outside door handle and the other half of the actuator connects to the linkage of the inside door handle.
The issue with mine is that the door is almost impossible to open from the outside, I know there is a threaded piece on the linkage but messing with that does not help, Thanks.
Basic Sponsor
Basic Sponsor
Linkage
You may need to bend that door rod lever straighter. It normally stays on the door handle . Did you hammer the pivot pin out to remove it ? Otherwise that secondary lever far right should be attached to the door handle. It looks like you can un-thread the rod lever from the black plastic ball socket piece some.
Normally to remove the door lock mechanism, you would leave the handle in place and just unsnap the white and black ball sockets. There is no need to remove the handle. Seeing that your handle opener pivot is detached makes me wonder why. Take a look at these handles and maybe you can compare them with yours. It seems the door linkage rod may just need straightening and re assembly to door handle.
If you re assemble the lock in the door, less handle you should be just be able to reach the lock and open levers with finger tip and SB able to manually open and lock to check operation. LMK if that fails I do have a 86 door lock assy $20 shipped, no handles though.
