Opening up DME
Opening up DME
I made a short video while I opened up a spare DME. I thought it might be helpful to anyone looking to upgrade chips or looking for cracked solder joints.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Van, as usual you have made another top notch video that was much needed to help us understand how to get the DME / ECU apart and what to look for.
Thank you,
Larry
Thank you,
Larry
Van, thanks very much for sharing this with us.
Could you please elaborate on the fuel quality switch, and how it may be adjusted for optimum power and fuel economy?
Two other things:
A common fault in these units is the ignition trigger, the round silver thingy on the left side of the board near your left thumb at 6:37 into the video. This can be cheaply replaced for about $5 from an electronics supply house. Its solder joints are common faults due to hairline cracks from thermal cycles. I've read that when the DME fails, it's often just the ignition trigger, an easy DIY fix. I keep a spare DME with new trigger in my glove box.
Chip notch: BEFORE removing the chip, note which way the notch faces. Be advised, however, that in my case that particular eBay aftermarket chip had a notch that faced the other direction, so when installed, the car would crank but not start. I was afraid to reverse it, lest I damage the engine or computer. Finally, I bit the bullet and reversed the chip, the car started right up and ran fine with no ill effects. Be cautioned, however, your results may not be the same, so note the notch orientation BEFORE removing the original.
A $5 soldering pen or 5 in 1 hobby kit (wood burning pen with selection of fine points and blades, HF item no. 38593) from Harbor Freight has fine tips that make an excellent tool for reflowing small solder joints without messing up nearby points. Wear good glasses and/or use a magnifying lens to see what you're doing, as cross-flowing solder joints is a risk here. It may be best to heat the tip of one connection, then let the heat flow from that tip to heat and reflow its solder, rather than just touching the solder, which can get sloppy. Soldering experts, please chime in here and correct any misinformation.
Also, crud and corrosion gets into the various connections and sockets between chips and board, ribbon tape, etc. GENTLY prying them apart after noting how they fit, and a quick spray of electronic contact cleaner ($3/can at Walmart) does a nice job of assuring good electronic contact.
It may be worthwhile to consider warming the open unit in the oven for an hour at ~180 degrees to get any moisture out, spritz with WD40 moisture repellent before closing the box, and/or sealing the box with aluminum foil tape. Electronic experts please chime in here and correct any bad info from me.
Two other things:
I suppose, for max fuel economy, you'd want position 6, which reduces the fuel and retards the timing.
For more on the FQS and its settings, look here: http://www.motronic.ws/fqs.htm
p.s. do you have a p/n for that ignition trigger?
On using soldering equipment, get a fresh wet household sponge (like the kitchen ones) and keep it just damp, not dripping and every few soldering applications, wipe the tip on the sponge and apply a little solder to the tip right after. The searing of the tip steam cleans the old residue away and the new solder applied to the tip "re-tins" it so it'll work clean and faster. This is a practice all professional soldering techs use, especially on aerospace applications.
Recommended wattage on pencil irons is 60 watts so you don't do heat damage to wire traces (lands) on circuit boards or small components.
Shown is a Weller soldering "station" commonly used in professional shops (note yellow sponge) goes for minimum of $145 but a simple pencil iron of proper wattage and damp sponge can be had for less than $20 at Radio Shack.
Basic Sponsor
Great video - thanks for sharing!
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Well, for max power, you'll need to do tests on a dyno in each position... but, generally, I've found the position 3 (+6% fuel) yields an extra HP or 2.
There is a printed mark under the socket which should help you figure out which side of the socket the notch goes. Interesting about your chip with the backwards notch!
I don't have the number handy, but got it some years ago for about $5 from DigiKey in Minnesota. If you have the number printed on the stock DME ignition trigger thingy, perhaps that number will cross-reference with a DigiKey part number.
