Electrical Problem - Help!
Old 01-06-2014, 06:53 PM
lina944
lina944's Avatar
Default Electrical Problem - Help!
My fellow 944 owners...I'm hoping I can get some insight for an electrical problem that I'm experiencing in my 85/2 944.
I've been trying to isolate the problem today but can't seem to find out whats going on. When the terminals are unplugged, the battery reads ~8+ volts. When i plug in the terminals the battery reads at 2.5 Volts...indicating there is a short somewhere - I suppose. I pulled all the fuses and relays, but still at 2.5 volts. I recently installed an instrument cluster from another 944 at the junkyard so I pulled it out just in case and its still reading 2.5V(plugged in).
Not sure what it can be! I read something about it being the alternator but the car is able to keep running after I jump it, however the battery meter on the cluster reads around 10 volts.
Any help is greatly appreciated!
Old 01-06-2014, 08:41 PM
austin944
austin944's Avatar
Are you saying the battery reads around 8 volts with the cables not connected to the battery?
Old 01-06-2014, 08:53 PM
travisgreen
travisgreen's Avatar
Originally Posted by lina944
My fellow 944 owners...I'm hoping I can get some insight for an electrical problem that I'm experiencing in my 85/2 944. I've been trying to isolate the problem today but can't seem to find out whats going on. When the terminals are unplugged, the battery reads ~8+ volts. When i plug in the terminals the battery reads at 2.5 Volts...indicating there is a short somewhere - I suppose. I pulled all the fuses and relays, but still at 2.5 volts. I recently installed an instrument cluster from another 944 at the junkyard so I pulled it out just in case and its still reading 2.5V(plugged in). Not sure what it can be! I read something about it being the alternator but the car is able to keep running after I jump it, however the battery meter on the cluster reads around 10 volts. Any help is greatly appreciated!
Your battery is dead, get a new one or use a fully charged one, then diagnose
Old 01-06-2014, 10:14 PM
konakat
konakat's Avatar
Yes, that battery is so dead almost any load will make it go completely flat. Most likely there is no problem except your dead battery.
Old 01-06-2014, 10:51 PM
lina944
lina944's Avatar
Although the battery does need to be charged after all this, it's new. I'm worried that there is a short somewhere though since the resistance between the positive terminal and negative terminal (unconnected) is less than 200 ohms....
Old 01-06-2014, 11:02 PM
konakat
konakat's Avatar
That's doesn't sound crazy. 12 volts divided by 200 ohms is 60 milliamps, no big deal at all. It would take a very hard short to flatten a good battery, like a thousand amps.
Old 01-06-2014, 11:53 PM
Racerstev
Racerstev's Avatar
The battery needs to be at 12 volts to check anything. Charge it up and
set your meter to check amperage and see if you have a draw.
Steve
Old 01-07-2014, 12:07 PM
austin944
austin944's Avatar
I think you mean there's a battery drain, not a short, right? So you had a brand new battery connected, and it went dead (perhaps due to a drain), and now you're trying to diagnose the drain?
Old 01-10-2014, 11:20 PM
lina944
lina944's Avatar
Battery is charged and seems to be working fine! A it needed was a charge I guess lol
Quick Reply: Electrical Problem - Help!
