After replacing the front seals, timing/balance belts, dialing the AFM, new power steering hoses, oil pressure sender, dealing with vacuum leaks, rebuilding the cluster, the clock and the power steering pump and installing TWO different steering racks, my (heated garage) "barn find" is on the ground and RUNNING.
