Will an S2 intake bolt up to an 8 valve head?
Wondering if the bolt pattern is a match? Not concerned about port match unless its crazy off. Also does anyone make a poly isolator for 944/951 heads?
TIA
Broken
TIA
Broken
Below is the link for the Phenolic Spacer Kit you asked for... (second item down on the page and for a NA Or Turbo head Only)
http://philsautomotiveltd.com/wp/?page_id=2
Would a phenolic spacer even be much benefit to an NA car?
I understand getting every bit of heat separation is beneficial, especially in turbo applications, but I feel unless you're very serious about racing the difference in an NA car would be negligible at that cost.
Basic Sponsor
Peter, is that you?
Please reread.
