seating position RE: steering wheel (EARLY)
Hey guys, on the early dash, what is your position? I know its relative but I feel like if I set the seat the way I like it, relatively upright, ( for reference, my head hits the end of the sunroof air deflector(broke/ hanging down) Then i have to put the seat almost all the way back. (unless there is some junk on the rails that stops it from moving further back).
Im 6ft, with a 32 inseam(add an inch with shoes), size 12.5 shoes.
With that position my knees still hit the steering wheel. (but I have to fully extend my leg to bottom the clutch pedal) (And does anyone ever really push the clutch ALL the way in??)
SO, I intend to get a smaller steering wheel, preferably with a flat bottom. But with this position I feel like I want the steering wheel about an inch further back.
any one else do or feel the same??
(and do you always have to practically fall out of the car to exit?)
i am 6'6" and my knees don't touch the wheel unless i am flailing my arms around like a madman.
i also have a slightly larger-than-stock diameter steering wheel.
i sit with the seat slid all the way back but still fairly upright and it is cozy.
getting in/out is easy (years of practice) but the damn e-brake lever gets in the way every time if i have long pants.
Today I got
My Custom Title
My Custom Title
From: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
Small diameter wheel + quick release hub FTW! The steering wheel being smaller obviously helps, and the quick release hub pushes the steering wheel another inch or so outward, so works out well. I'm 6'1" here, sit pretty comfortably. I absolutely love having a quick release racing hub, 1) because racecar and 2) 10000x easier to get in and out.
Agreed on the Ebrake being a PITA.
I'm kinda short so I have the seat forward a bit and my leg hit the wheel on occasion. It's just low I guess.
Pretty much. I have a system where I swing the door open kinda hard and let the momentum pull me out.
For what its worth, I have a really nice black steering wheel from an early car. Will fit others. Its the somewhat rare M018 option code - SPORTS STEERING WHEEL WITH ELIVATED 30 MM HUB
asking $125.... Pm if interested.
I have a Momo wheel that's extended out a bit.. I want to say 30mm? But I've never measured. I never hit my knees on it, but I do with the stock wheel (larger diameter). Stock seats and rails.
I'm 6'2" and wear a size 12, and this car fits me like a glove. I haven no problems at all with pedal reach, although I have a custom throttle pedal which might help. PO who put it on was also a tall guy.
I'm 6'4" and the stock wheel was a bit tight on my leg between the wheel and the center console. I did the logical thing and tore the center console out. Now I have plenty of room. Who needs a stereo, AC/heat controls, and a cigarette lighter anyways?
I have some garbage rice-burner "race" seats that the PO put in that are probably a bit higher than stock. I'm practically laying down I have them so far tilted back so I don't hit my head. Those will be replaced shortly.
I would like to get a smaller wheel still though for even more space. After having no power steering in my '70 Landcruiser turning 35" tires (a workout in parking lots!) I'm sure turning the Porches tiny donuts with a smaller steering wheel will be no issue.
with a smaller wheel you can keep the center console
and does any one fully bottom the clutch pedal? or is it adjustable? Im good with the gas and brake, but would have to stretch to bottom the clutch, or else id have to move the seat on notch up which id rather not do.
once warmed up though you can shift by moving the clutch pedal almost not at all
